Guest biscowar
Problem to solve: I have a very old heating sistem. There is only one thermostat controlling a pump, and when thermostat go to on all the fan coli start to work. Now i want to use fibaro to make the fancoil independent, using a remote switch FGS211 and EVERSPRING ST814. This is simple but i have to turn on and off the pump. So when 1 heater start the pump have to be put in on, when another heater start the pump have to stay in on, but whe one of the heater go to off and 1 is stil in on the pump have to stay on.
If temp reached -> turn off fan coil -> else stay on
If ALL fan coil temp is reached -> turn off pump -> else stay on
How to solve?
