What kind of unit do you expect
176 members have voted
  1. 1. What kind of unit do you expect
    • Universal actuator module
      31
    • Detector: smoke / gas / other
      38
    • Module related to safety: opening sensor, etc..
      32
    • Exotic: RGB Controller, etc...
      32
    • Gateway to other technology
      44
I hope an actuator module (contacts) in the same format as the universal module.
Guest m.rodziewicz
Hello. We are very close to release the:
- door / window sensor and universal sensor battery operated in one device - release 1st week of Novemver
- Plug with power metering ( smallest in the world ) - 4 weeks from now.
- PIR with Light sensor - December
- Multisensor - December / January
    Excellent news
    Guest m.rodziewicz
    I have do add to this - modules with power metering - December / January.
    I cant wait this.. I wish more fibaro devices to come.
    Excellent news
    Guest MitchellOnline
    Where are the new devices? Shouldn't there come out a new device in the first week of november 2012?
    /emoticons/default_icon_question.gif" alt=":?:" />
    Exactly
    if there is no change in the communication of "Fibaro" I think well sell my box and go to a competitor, I'm out of patience and I am not alone in this case
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    Guest skeal
    i'm planning my switch to ip-symcon with an aeon labs usb stick ... seems to be the better way ... with ips i am able to do much much more with less money[/hide][/code]
    Guest Cirion
    Less money?!? It's 499,- €* for a software, you still need a PC, Aeon labs USB Stick and a subscription after 12 months. Topp that off with charging for support too...
    Guest skeal
    99€ plus Stick plus any Windows driven PC. Or 250 for Professional
    • 3 weeks later...
    Just want to know if it is FGD211, FGS221 modules that come in new version with power consumption measurement.
    Really want to expand the system but do not want to buy the old modules.
    Something new releasedate for these?
    Plug with power metering (smallest in the world)
    Top that off with charging for support too...
    I'd pay for support. At least then I'd know someone was contractually obligated to provide some, and indeed incentivised to provide it.
    some devices Fibaro could create which make users very happy:
    - dimmer with 0-10v control
    - dimmer for low power led (max 20W)
    - change current dimmer to be able to choose trailing edge/leading edge (or autodetect)
    Cannot agree more on these three. In the EU LED lighting is being pushed instead of old bulbs. We need above devices *quick* to be able to use the LED lights with Z-Wave technology.
    Also, I'd like a universal binary sensor that does work on a 9V battery longer than a day or three. I'd like it to go into sleep and wake up after n amount of minutes (adjustable via param). I don't need the readings from the dallas temp sensors every minute, once in 15 minutes is fine. Being able to use them without a powerbrick is a great advantage. Hopefully this will become available as a firmware upgrade to the current module?
    Power metering ? LOL, the module with power metering and when your box manage power metering ???!!!!
    • 1 month later...
    Guest giz
    I hope next product will be working hc2.
    what i am affraid of is that fibaro ditches hc2 and releases a hc 3 and leaves his customers left with a non working product
    It should at this point all be software. The only reason I could see for why they would do that is if there is a hardware architectural problem that they try to hide by releasing a new product instead of doing recalls.
    Where there ever even an HC1? If so, when?
    Energy switches are going to be available very soon.. so be prepared
