Danfoss Living connect zwave module
Dear Fibar team,
I've setup 8 Danfoss Living connect thermostatic valves on the HC2. The valves have all the same firmware version 2.06 (that is z-wave compatible).
The strange thing is that all valves are not recognized the same way on the HC2 :
- Some of them appears on the HC2 as "device kind: thermostat" and "device type: Danfoss Living Connect Thermostat",
- Other only as "device kind: Thermostat" but with no device type, meanwhile, the icon is correct and show the danfoss valve, but there is no way to set parameters.
Any idea how can I fix it ?
Guest Kuuno
The first thing to do is remove and readd the device, have you tried that?
jiminy68, please do as Kuuno said. Please remove it and re-add it again. Maybe it has not configured itself properly.
