deleted relay
Guest biscowar
Version 1.037
after deleting a fibaro relay switch, i tried to reassociate it puscing for 3 or more second the button on the switch. The association seem to be ok, but i have no new device on thedevice panel
Guest thales almeida
    try to restart the hc2
    Guest biscowar
    I've solved the problem. The problem is in the operating manual fo the switch. instead of writing "push the b butto for 3 TIMES" they writed "push the butto for 3 second". Fibaro support is not good as the operating manual.
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    Where did you find this bug in operating manuals? Can you give me exact link?
    Krystian,
    The Fibaro manual is
    For inclusion it says
    STEP 5
    Add Double Relay Switch to the network by pushing three times key
    no. or push-button B located inside the housing of the device. For
    bi-stable switch perform 3 position changes.
    for resetting, it says
    Method III : Reset by holding B button for 3 sec. after connecting mains voltage to the Switch
    The Inclusion instructions are perhaps somewhat ambiguous, presumably, is it trying to say push button-B three times. Maybe that's where the confusion came about.
    Krystian,
    STEP 5
    I understand that resetting is different from adding/removing device.. so If you need to add or remove module from your system, you have to push 3 times this button (as it says in manual) but if you need to reset the module - then hold down 3 sec.
    For removing you have to choose "remove device" from HC2 interface and then push button 3 times.
    Reseting is completely different procedure that excluding/including.
    Excluding remove device also from the controller, while resetting clears module EPROM memory.
