Aeon Labs MultiSensor
jonny
13 answers to this question
+1, I would like use my Aeon Labs 4-1 "Multisensor". Any chance in next update ? Thx.
Guest MitchellOnline
+1!
@Fibaro When will the Home Center 2 support all 4 functions of this sensor?
I really need support for this sensor!
/emoticons/default_icon_exclaim.gif" alt=":!:" />
Guest eshaabo
I just added the Aeon Labs multisensor, but it is not functioning.
My Fibaro revision 1.044.
Did anyone successfully made it work.
Bump
any news on the sensor, i have one and wanna use al of it features
Guest deraaij
In the new beta it recognizes all sensors. I know for a fact that when you use it on batteries it will sometimes reset the values to zero and pick it up later again.
Mark
Bump
The motion detector bugs out with the wrong icon and no arm/disarm buttons. It works for a while after inclusion but then it screws up.
The other ones work as expected although they come and go sometimes as mentioned.
Got to do some more troubleshooting still...
(This is in beta 3.341)
Bump
Some time on my HC2 with the same beta i have my 4 icon = the first ....
Kind regards
Pascal
In the Beta 3.424 the Aeon will still not work .
All the devices are available but no data.
Also the motion will not work.
I have tested with batteries and power connected.
Motion works just fine with batteries and power connected - no problems... other devices are always zero and this is reported several times in bugzilla also.
I think one of the problems is my zwave network this is not stabile at the moment with the beta software
Can you please check how often you are getting a echo?
Even when there is o movement.
Device will report movement all the time even there is no movement.
Guest Kuuno
Bump
can you post what parameters you have for the sensor
thanks
