Guest Kuuno
yesterday i received small package from aeotec to test some devices
it included
4-1 sensors, minimotes, ztick
minimote was recognized by the system as controller and i could add it as secondary with no problem. I must say that that rest configuration i had to do using minimote but it was easy and straightforward. all on/all of worked right away and triggering groups of devices was easy
scene association is something that comes with new software release of HC2
4-1 was also recognised right away but for not making all things too good it was found as movement sensor only (previously stated in forum also). the device itself looks good and can be used very well after support is added. i especially liked that it can be mounted to ceiling for 360 degree view angle. So for now using it as motion sensors to trigger lights and so on...
if you want any tests to be done with these then let me know!
