I've just loaded 1.040 and can't see much difference to 1.037 or 1.039.
20 answers to this question
Guest hotrot_net
Just installed that one to, no changes here for so far as I can see
No changes, update only for danfoss product improvement ! Seems more reactive with my dimmer
My minimote aeon labs still not supported... But two update in few days I still believe
Is anyone else having major issues with their iPhone application after this update?
Yeah, app loads but cant go into any section ie Lights
    Just checked mine over 3G and same thing. None of the buttons work.
    Guest domoticawireles
    I have the same problem...
    Same problem! Only light dead node awaken are ok! But seems more reactive now...
    Guest DennisNL
    Same problem here! Nothing works any more on my iphone and ipad. (different iOS 5 and 6). But nothing works
    Guest Kuuno
    worked for me 30 min ago over 3g
    maybe something was temporarily down?
    Guest Dennis
    Yes. its working again here. (but only one my iphone (not ipad)
    Appears to be intermittent for me
    We've released new 1.040 software version.
    For correct display of the update progress, we recommend refreshing the page (CTRL+F5) before starting an update.
    - New parameters templates for devices ver. 1.9 and 1.10,
    - Improved support for Danfoss living connect electronic thermostats,
    - New language support - Estonian.
    We are very sorry because all inconveniences regarding iOs access issues. It was not releated with 1.040 update and it was solved just after first reports.
    Hi all,
    EZ-motion 3 in 1 sensor no more work since update 1.0.40.
    Worked fine when i was in 1.0.37.
    Deleted and added it again but module not recognized anymore.
    Anyone have the same issue ? Any idear of what's going on ?
    The door bell TSE03 from Everspring still not reconized with this update...
    in opposite, with update 1.0.40, i notice that i have no more dead node in my Z-wave mesh with my two AD142 Dimmer Plug from Everspring.
    the GUI is also more reactive. Good point.
    no more dead nodes ( fibaro modules). Vert good point.
    Few scènes dosn t work.
    Guest Futuretech
    Hi all,
    I had a dead HC2, got a new one.
    After installing immediately updated to 1.0.40.
    Cannot add EZMotion 3 in 1 sensor.
    Can't even add a fibaro switch module (distance aprox 15m)
    Guest Kuuno
    when you add 3-1 sensor how many times you press the button on the side?
    I assume that since your old HC2 dies that you didn't remove it from the original one so it will still be assigned to the Home ID of your previous Home Center. This is used so each device can only be controlled by one HC2. (You could have 2 HC2 units in your house but they could only control the modules assigned to that home ID)
    Kill the supply to the module completely, turn the supply back on and immediately hold down the B button for around 5 seconds. This should reset the module and allow you to remove the association to your previous HC2.
    There is probably a similar situation in place for your 3-1 sensor as this is a Z-wave protocol. I'm not familiar with the factory reset for these devices but there should be something in the manual
    Guest Futuretech
    Only once about 5 secs
    Added
    Now figuring out why my relayswitch won't add
    Guest Kuuno
    for 3-1 sensor you need 1 short click and then wait
    for fibaro modules 3 clicks
    Guest Futuretech
    sorry,
    Forgot to edit my last post, got it running again.
    But thanks anyway
