If I use a single mono stable switch with a Fibaro FGD211 does it do this??
A single push turns light on.
Light is on and now pushing the switch again turns the light off.
Light is on and then holding down the switch will dim light.
Light is on and then holding down the switch will brihten light.
Does the Fibaro work like this? I need to plan how I will make my switchplates. I would prefer to use only a single switch on the wall.
Anyone confirm please?
Guest miguel.araujo
that's exactly how they work
You can also add to your list: Double-click and it will turn the light 100% if it was dimmed before.
Miguel
    OK thanks. I just ordered 10 of these.
    what mono stable switches did you find to use with them?
    I go to Shenzhen and got LED backlighted mono switches made there.
