Trigger a Fibaro scene from your desktop?
Would it be possible, in any way, to trigger a scene from your PC? As it is now, if I would like to force a scene to run, I have to log into HC2 and then click Run on the specific scene I would like to run.
Some kind of "shortcut" on the desktop or in the taskbar would be ideal!
4 answers to this question
Guest skeal
You can use http control with a Web shortcut on your desktop
    Thanks a lot!
    I know how to make a shortcut to the HC2 web login page, but I guess that I, in some way will have to know how to extend the shurtcut's address field in someway in order to get it to log into HC2 and then trigger a specific scene?
    Guest skeal
    I can write down an example link later when I am at home
    Guest skeal
    try this:
    http:///fibaro/externalRequest.php?id=runScene&sceneID=
    replace with your ip and with the ID of the scene
    you can find more examples here:
