alex88 71
I'm putting it out there to anyone that can help with my heating solution.
My situation is that I have a mid-terrace house with approx 12 radiators installed in 10 rooms including bathrooms. I have a combi-boiler that is controlled via a battery operated thermostat which I suspect simply sends a signal to turn the boiler on or off based on the temperature threshold that I program it with.
I would like to be able to measure the temperature within each room and turn on or off the radiator in that room when I need to, for example, if one or more radiators need to be turned on then the boiler will turn on and those radiators will turn on. Otherwise the boiler will be off and the radiators will all be off.
My other requirement is that everything be mains powered. I will make sure that I can make mains cabling available where ever possible, however the solution has to be reasonable in its requirements for cabling as exposing new mains cable will cost quite a bit extra.
I do not have any allegiance to any manufacturer and am willing to take on which ever technologies I need to make a stable system.
Can you please suggest a working, stable solution that integrates well with Fibaro, will not cost be an arm and a leg and will be manageable to implement, configure and maintain?
Please consider that from my research and given that I can not re-zone my house (the heating currently works off of a single loop) it seems like the best solution would be to install some type of TRV *thermal regulating valve" at each radiator and have Fibaro HC2 control these based on individual temp sensor readings used in conjunction with scenes. That said, I do not want to tell you how I should do this, but instead get your advice of the best solution for me.
Finally, I like the idea of having override capability in some rooms via a temperature control units like this one (
) that I am planning on installing in a bathroom when I get under floor heating installed, but i can't see how this would work with Fibaro.I know this is a big set of questions, so if there are any how-to guides out there that you know of please direct me to them.
Thanks in advance!
10
6
6
Dec 11
9
Dec 16
7
Nov 9
6
Dec 12
4
alex88 12 posts
davedotnet 10 posts
stevenvd 6 posts
hvb83 6 posts
Dec 11 2012
Dec 16 2012
Nov 9 2012
Dec 12 2012
57 answers to this question
