Push notifications request!
It's essential for my installation and security ... Security is a big marketing aspect of fibaro products ! I have paid for that and I want it! Please. Best regards.
7 answers to this question
For which function do you wish to receive notifications that the HC2 currently does not support?
    Thank for your reply johnnyC, I want receive notification when the garage is opened for example and not by email with the delay that goes with! Or for example when a scene that handle suspicious intrusion push to me notification then I can take control of my camera.
    and sorry for my English
    Best regards.
    But you can do this with a simple Z-wave Door/Window sensor.
    Also, depending on the available connections on the garage door motor you could potentially monitor/receive notifications of this status using a universal sensor which would be a better solution to avoid potential issues with battery powered devices. You could receive the same notifications from this device
    Ok thank so much for your support
    /emoticons/default_icon_biggrin.gif" alt=":-D" /> I really appreciate, but I already tried all that and nothing work ! What is your version of HC2 ? Mine is current 1.040 and last iPhone app 1.4 I think ?
    /emoticons/default_icon_cry.gif" alt=":cry:" /> I just realise that my aeon labs smart plugin dimmer is Dead Node again and the HC2 doesn't want...but everything works very well for three days... I am off topic
    /emoticons/default_icon_curve.gif" alt=":-/" /> I hope soon a new stable version
    Best regards
    Check the following things.
    On your HC2... Panels > Access Control Panel
    Ensure that your user Settings are set to receive notifications and your iPhone is listed and selected at the bottom of the screen as a device that can receive push notifications
    On your iPhone... Settings > Notifications
    Select "Manually" and scroll down to "Fibaro HC2"
    Make sure "Notification Center" is on
    Yes, it works with no problems!
    My Iphone is listed in this panel and already checked...
    Select "Manually" and scroll down to "Fibaro HC2" Make sure "Notification Center" is on
    My Iphone app is configured correctly and exactly as you say...
    it does not work then
    /emoticons/default_icon_idea.gif" alt=":idea:" /> First I deleted all the notifications created before, then after I rebooted the box, after restart, create a new notification request and it seems to work now
    But mystery... This confirms what I already thought for a while, the Fibaro HC2 is not very stable and is not sufficiently mature, may be in the next version ?
    Thank you very much for the time spent trying to help me solve my problem.
    Best regards.
