Hi!
I am looking for advice on which electronic transformer to use in conjunction with a fibaro dimmer and 12v halogen lights. I just had my electrician hook up the dimmer to the existing setup, with the transformer below. This does not work.
Advice on a specific electronic tranformer would be appreciated. I need to hook up seven 20W halogen downlights in parallel to the transformer.
Thank you!
Diderik
Osram HTM muis trafo 105 HTM105 halogeentransformator
Try this one!
    Thanks a lot! I will try!
    Diderik
    [ Added: 2013-06-01, 11:23 ]
    I finally got this hooked up, and it works! Thanks!
