After 1.041 upgrade I see a device that doen´t exist
and the main problem is that I can´t delete it.
I've tried several times and I'm allways getting "HC2: Deleting device error"
And that devices doesn´t exist!!!! (it shows a motion sensor)
Please help!
Thanks a lot
4 answers to this question
    And it´s still happening with new HC2 1.042 version
    I had the same problem. Firstly run Your hc2 from backup before You updated to 1.042 So You should turn back to 1.040. Version 1.040 should help You with device which is useless and You do not want it! Then You will be able to make update to 1.042 and everything should be all right.
    Good luck!
    That takes to much time and I think not the way to correct a bug. I have the same problem with a non excisting Danfoss Living Connect that I can't remove
    It is the way to correct the bug. Turn back to 1.040 this will fix problem with non excisting devices. Then make update to 1.042. It should take no more than 10 minutes.
