Danfoss and Scene
i created a scene named: Shower time.
This will set the temperature of the shower room to 24 degrees. this is ok! it is perfect it works.
The only problem it gives a command to go to 24Degrees for 2 hours. I need it to be only for 1 hour.
Is it possible to setup also the time of the specific thermostat? or not?
I made something based on my current conf... but an better setup would be great for me.
check the image
Guest MitchellOnline
check the image
You can also use the heating panel. Here you can use manual temperature override.
    The problem is that through the android beta,, you cannot have a heating panel.
    and the thermostats do not get commands through their panel. So the only way for me is to make a scene. Or to find an app to execute url's and close the browser. A nice app to be like a panel.
    The only resonable way to do it is through a scene.
