virtual device does not appear on iphone application !?!
Guest Plume
The virtual peripherals that I created for moin IPX800 not appear on iphone application.
Why?
thank you
9 answers to this question
Why?
thank you
Hi Plume,
It is normal, it fibaro application !!!
bye
Guest Plume
    How do I do then ?
    You cannot display Virtual Devices on the iPhone app. There is no way to make this happen. You will have no access to Virtual Devices on the iPhone.
    It's possible in the Windows Phone application..
    Guest Futuretech
    Haha,
    Winphone app
    Let me guesss, it's not a Fibar app
    Guest kenlomi
    Is this Virtual devices cannot be also view in IPAD?
    In the short term you can create an individual scene for the buttons you want to appear in the iPhone interface. They will obviously appear under the scenes button (in random order) but if you only have a few buttons connected its a solution in the short term.
    Guest kenlomi
    It would be possible but what if there is another IR devices to be controlled not only TV?
    There is also 1 DVD, and 1 IR remote controlled AIR conditioning system. what will gonna happen if they are mix together and you said they will be random. Maybe they should have 1 1room in every devices. But how?
    Guest Plume
    Thanks, at short term I use this ! Please fibaro to change this problem !
