Danfoss Association
I want to associate 2 (or 3) Danfoss valves in the same room to one -valve- . I am sure there was such an option (or has been communicated). Of course I am able to associate 2 light switches, but how to combine the Danfoss valves?
>> And Fibaro, please change the setpoint list on the Danfoss valves, 4 or 28 degrees and all the 0.5 options can be deleted I think.... At this time the list is much too long.
7 answers to this question
Why do you want to associate if they are in the same room ! Use heating panel, create new zone with the room, set temperature and hc2 do all the work
Absolutely NOT! I do need 0.5 degree settings and would like to have them in the heating panel as well. Of course you must be able to set all temperatures that the device can produce!
    Biigles, you are right, however, for manual changing the temperature, the list is much too long (probably 15,16,17,18,19,19.5,20,20.5,21,22 will do fine!) and therefor it would be nice if the list would be configurable...
    Krikroff, Maybe I am missing something, but I have the house already with rooms and I would like to change the temperature in a room, so why should I make zones? Also because switching the light etc... goes also from the -your house- screen. Why do I need to manual change temp in the heatingpanel (with extra zones) and I think no Iphone support ?? What am I missing?
    Marcel, I've just been reading the Danfoss ZWave document. Couple of observations. 1) the device does not support the COMMAND_CLASS_ASSOCIATIONS so there is no way to have an event inside the Danfoss trigger any external activity in another ZWave device, including the controller. 2) Additionally, the Danfoss device does not support any COMMAND_CLASS_BASIC or any other command class that allows another ZWave device (including the controller) to control it as an endpoint (in terms of opening/closing the valve). Setting the SetPoint seems to be the only real function it supports. Then it's autonomous.
    Not possessing one of these, how does the valve show up inside HC2 ?
    It looks like it works fine (except for the long setpoint list), the icon is a picture of the valve. In 1.043 I have some issues with the time-setting, you can not set the setpoint and the time to 0 seconds (unlimited). Just does not work correctly....
    About association: Maybe I used the wrong -word- for it? Should I use -Linked- device? Having 3 valves in the same room at the moment, very strange to have to set the setpoint (and time??) on 3 valves in the -your home- screen of the HC2. Just would like to set the temperature for the room (and not use the heating panel, as this does not work correctly either in 1.043 in my HC2). Having an option in the -rooms- section would be nice aswel, but not their either....
    >> Is there any option available to pass the HC2 login screen automatically? Do not have use for it on my private network....
    Ok ! I understand what do you want but I think you cannot do that with the actual heating panel, perhaps in the V3 if the heat panel was revisited I don't no!
    The only way to set the room temperature with DAnfoss LC is set separately from your iPhone or set globally with heat zone program...
    But another limitation with Danfoss LC is the wake up of the device, DLC listen Zwave only in wakeup periods.
    Good luck.
