FGD211 won't switch on/off after associating
I recently installed a couple of Fibaro FGD211 dimmers and an Aeon labs z-stick. Got the dimmers installed behind push button switches in the 2-wire configuration (with a load of 150W). Everything is working perfectly (on/off on push, dim on hold) until they're associated to the stick ...
After association i can no longer locally switch on/off by a push of the button. Dimming (by holding the button) does work. Operating through zwave also works normally.
To turn off the dimmer i need to hold the button until it starts to dim and then giving it a push (just a push won't work), to turn it on i have to hold the button (just a push won't work).
I tried to delete and reassociate the dimmers and even did a reset of the stick but as soon as the dimmer is associated to the stick (stick not plugged in, so no software is running) the problem occurs, as soon as the association is deleted the problem is resolved.
Anybody got any clues?
Just curious... What software are you using with the Aeon Z-Stick ?
    The stick firmware is 5.02P3 ...
    Edwin, sorry, I meant what controller software are you using with the ZStick.
    Ah
    /emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> The problem already occurs without running any controller software at all, just associating the loose (and empty/reset) stick is enough to trigger this. The dimmers seem to be version 1.9.
    • 1 month later...
    Just for visibility, same problem here:
