I want to setup my HC2 as an alarm system.
I saw that you can integrate with an already existing alarm system. But I want use the alarm feature of HC2 without having to integrate with other system.
Meaning, when I select "arm" any change of state of any of my modules or sensors would (or the ones I choose) would be a breach and the alarm would go on, notifying my cell phone with a push message and making all the lights blink, siren on, etc.
I could check in the iphone app if the alarm is armed or not. If has been breach or is safe. Just like when you integrate with an alarm system.
Can it be done?
I've tried a scene but, the scenes don't let do "IF devices change state then..." only equal or different of ON/OFF/ARM/DISARM/etc.
And I can't set alarm=breached
More to that I prefer using the already existing alarm interface, so it would show in my iphone app.
How do I do it?
15 answers to this question
I too have the same problem, I have 5 sensors, door / window, the motion sensor and siren.
Yes you can, using scenes.
You need one FGS221 V1.7 Switch ON OFF 2x1,5kW and a siren.
attach the siren to S1.
S2 is virtual or attached to a keyboard.
Make a scene Alarm devices like this.
Door sensor == Breached and armed
OR
Or
Movement sensor == Breached and armed
THEN
Alarm office (S1)= Turn on
AND
Alarm office (S1) = Turn off 300 sec.
Make a second scene Alarm on.
Alarm on (S2) == ON
THEN
Devices group (all your sensors) = Arm
And the last scene to turn the alarm off.
Alarn on (S2) == OFF
THEN
Devices group (all your sensors) = Disarm
Scenes are not show'n in the interface.
Change icon like you wish, and set S1 and S2 as other device, and show no slaves.
Tjeerd.
Guest pablotibis
Guest hotrot_net
I ran into that problem to, this is how I did it.
1. make a new variable
Call it Alarm (for example)
2. Create a new virtual device with 2 buttons
Button 1 Called Alarm On
Lua Code
fibaro:setGlobal("Alarm", "1");
Button 2 Called Alarm Off
Lua Code
fibaro:setGlobal("Alarm", "0");
3. Create 3 Scense
Scene 1 Called Alarm On
Lua Code
%% properties
%% globals
Alarm
if (
( tonumber(fibaro:getGlobalValue("Alarm")) == tonumber("1") )
or
then
fibaro:call(19, "setArmed", "1");
fibaro:call(28, "setArmed", "1");
fibaro:call(44, "setArmed", "1");
Scene 2 Called Alarm Off
Lua Code
%% properties
%% globals
Alarm
if (
( tonumber(fibaro:getGlobalValue("Alarm")) == tonumber("0") )
or
then
fibaro:call(19, "setArmed", "0");
fibaro:call(28, "setArmed", "0");
fibaro:call(44, "setArmed", "0");
Scene 3 Called Alarm Breached
Lua Code
%% properties
28 value
28 armed
%% globals
if (
( (tonumber(fibaro:getValue(28, "value")) > 0 and tonumber(fibaro:getValue(28, "armed")) > 0) )
or
then
fibaro:startScene(4);
The only problem is that I dont see any virtual devices on my iphone/ipad because of Fibaro not updating the tool..!! Otherwise I cloud see if the alarm was on because of different state of button icons.!
This is what I did and it works ok. I Created a virtual swicth out of a normal relay that I used for something else (show child: yes). Associated an Sms/email when this virtual device "alarmNotice" changes state.
Scene "alarm on", "runOnce" then set all sensors to Arm. This is the button to press after having left home.
Scene "alarm off", "runOnce" then set all sensors to Disarm. This is the button to press before opening the door.
Scene "alarm", sensor1 armed and breached or sensor2 armed and breached then "alarmNotice" set to opposite state and light on and ligh off (5 sec) and siren on and siren off (360 sec)
This gives 5 secs before siren sounds - it's important to add siren off after 360 sec otherwise siren goes off as soon as door is closed...
Hope it helps!
Riccardo
I would like to try this, but how do i define a variable ? or do i need the beta version ?
Guest deraaij
You can do that in the variables panel, which is also available in the stable versions.
Mark
idd i was looking there, but there is no add button
/emoticons/default_icon_question.gif" alt=":?:" />
btw, i saw its was your birthday today
Have a nice day
Guest hotrot_net
Arno,
Create a virutal device there is where you can make buttons
I know
/emoticons/default_icon_biggrin.gif" alt=":-D" /> but in the first step is says, create a variable, when i open the variable pannel there is no way to add one
Guest hotrot_net
Strange mabye it's because i'm on beta version, i've got a "add" button on the bottom. Do you have version 1.044? or the beta?
I'm running the 1.044 version, the beta version give mo to much errors
Guest deraaij
Thanks, indeed it is! Is there not am option on the top left when you are in the variables panel?
Nope, no add button
/emoticons/default_icon_redface.gif" alt=":oops:" /> . Also tried different browsers.
Maybe i have to upgrade to the beta version
/emoticons/default_icon_sad.gif" alt=":-(" /> Don't realy wanna do that because my webinterface is messed up and remote access is'nt working anymore
arnovanderhorst : The only way I know (1.044 stable version) to add a new variable is, enter in existing scene or create new one and go to variable Menu (click on "+" icon and select variable, enter in create variable panel,
/emoticons/default_icon_wink.gif" alt=";-)" /> )
Good luck...
Hey
/emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> there was he hiding
/emoticons/default_laugh.png" alt=":lol:" />
Thanks, i can add variables now
