BUG BETA 3
Guest Martial25
Bug beta 3
1) Problem in French translation motion detectors (door / windows and others)
2) Not possible to assign a scene in a room; backup does not work
3) scenes with the schedule does not run
Thank you
Martial25,
they run but you must have turn on option "Start with HC2"
Guest Martial25
    thank you. it works again.
    Regards.
    Guest Martial25
    Talking too fast ...
    The scene below is not working
    Beta 3.311
    1. The translation problem also appears in the English version
    2. The associations buttons for each device have disappeared
    3. The icon for my Everspring ST814 temp/humidity sensor is now a siren which can't be changed.
    4. Danfoss LC radiator thermostats no longer respond to temperature change requests and also can't be associated with the ST814 controller because of point 2 above
    Thank you for feedback but please report BUGs here:
    Thanks for the reply Krystian,
    Although I consider the above to all be BUGS that weren't present in version 1.043 and have only become apparent after 'upgrading' to Beta 3.311
