Fibaro FGS221 S2 combined with wall controller?
Guest jrkalf
I have a few Zwave.Me wall controllers and a few Fibaro modules. Especially for the FGS221 I'm looking for some help to create an advanced config.
I'm easilly able to pair the S1 of the FGS221 device to the zwave.me controller. As you push the internal B button a few times and it's paired. How do I pair the S2 to a physical controller?
My tools available for this:
- Zwave.ME controller
- HC2
- Optional: Monostable analog wall controller.
Guest jrkalf
    --- edit ---
    It'll have to wait a bit. the upgrade to 3.424 has fracked up my wall controllers in the zwave network. have to repair them and not crash my HC2
    /emoticons/default_icon_mad.gif" alt=":-x" />
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    I have the same problem - did u find a solution?
    Hi BSW,
    Yes and no. At first, original Duwi controller and z-wave.me controller are two different devices. They have the same hardware but different firmware.
    Original Duwi controller cannot work with Fibaro HC2. Ok, you can add it to HC2 and see battery status, but that's it. Duwi controller does not support sceneActivation functionality.
    z-wave.me controller is more interesting. It supports sceneActivation so you can use it for starting some scenes on HC2.
    Adding z-wave.me controller to HC2 is a little bit tricky. You have to wake up z-wave.me controller in the middle of adding process, otherwise HC2 cannot set up association groups. After successful adding you should have "Associations" block in advanced properties with Group ID:1 and 2. If you do not have this, you have to remove z-wave.me controller from networks and try to add it again.
