Dear all,
I understand the the Fibaro dimmer works well with a mono-stable switch connected directly to the first clamp in the sense it allows the user to turn the lamp on, off as well as dim up or down by holding.
Is it possible to replicate this functionality for the second switch when controlling a lamp module by association? Ie could i have it so in addition to the switch turning the lamp on and off, it will also dim it up or down by holding the second switch?
Many thanks in advance.
  • 3 weeks later...
Yes you can, I just tried this (have'nt thought of this possibility before), and it works like a charm, at least with V 1.044. Just set the association on the dimmer group ID: 2 to the device that you would like to dim.
