Guest deraaij
Just to share. I made an new virtual device with two buttons based on LUA and an autostart addon in xbmc. As a result XBMC will update a variable to 1 or 0 based on an event from xbmc is running. Based on the var you can run scene's (power on TV, receiver etc or the opposite)
On:
Off:
and a service addon in xbmc:
To be able to use the buttons I still have to include an UDP magic packet and a json command for shutdown based on the new HTTP/UDP functionality (no using curl). Will update it as soon as I have the documentation.
