Fibaro door/windows sensor
Guest hotrot_net
Ever since I did buy 2 door/window sensors by Fibaro I can't add them correctly to the HC2.
I got it working ONCE..!! but had to go back from 3.x to 1.044 because of problems.
Now the door/windows sensor is not connecting to the HC2 anymore. When I try to connect (pushing 3 times on the back) it flashes led fast and nothing happens.
I also rest is numerous times.
Can someone help me out here.?
Try pushing 3 times in different speeds. It solved the problem in my case when I did it faster then normally.
Guest hotrot_net
    Richo,
    Thanx for the tip..
    BUT what resolved it was 6 times push..!!! NOT 3 times..!!
    So first 3 times then real short pause and again 3 times..!!
    I tryied it several times to be sure, ITS 6 times not 3 times.
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    Hi
    For me the problem was that I was trying to include the sensor after having mounted it - this doesn't work, because the outside TMP is pressed when sensor is mounted, so pressing the TMP inside the sensor doesn't have any effect..
    My solution was to unmount the sensor before including it
    Hope it helps
    Riccardo
