Problems with scenes
Lauri
Hi, I'm having trouble to get one scene to work correctly, maybe someone can help me?
I have aeonlabs 4-1 sensor in my bathroom and if I enter the room - light goes on. Now I tried to create a scene where light is turned off if I forgot it or smth...
I attached one version of this:
laevalgusti = light
Liikumisandur = motion sensor from 4-1 sensor
Idea was - IF ceiling light is ON and motion sensor has been safe for 60sec (no movement) then it will turn OFF the ceiling light.
I also tried same scene with small modifications - IF ceiling fan is ON for 60sec and motion sensor SAFE THEN turn OFF light..
No luck so far... If i manually run the scene it works - but it doesnt work automatically. I have checked "start with HC2" option and restarted HC2 - no change..
4 answers to this question
Any luck with this?
I am seeing the same problem with LUA in the beta as well.
I'm not sure if its relevant but my 4-1 sensor is running off a battery, not mains. However with the HC2 home page open, I can see it change from 0 to 1, so I assume the HC2 has the upto date value for the sensor. However it never seems to start the scene.
Anyone have any ideas?
For those that are having problems. I resolved my issue by adding a section under %%properties
This appears to link the scene execution to the value change on the motion sensor
  • I didn't get it working and decided to go back to stable version.
    Can you explain what did you do exactly with %%properties?? I did'nt understand this at the moment.
    Unfortunately I cant show you the exact code as I am at work, and the beta doesnt work with remote access yet ;o)
    It seems putting something like :-
    %%properties
    39 value
    at the top of the LUA script means that the scene is triggered when deviceId 39's value changes. In my case, deviceId 39 is the motion sensor.
