Fibaro Door Windown sensor Scene.
Hello:
I can not turn on a light when the door opening sensor fibaro is open.
I use this Scene:
Fibaro Sensor == Opened (It does not work any variable)
Then
Light = Turn on
Thank you very much, sorry for my bad English.
ARIAS, if Fibaro Sensor == affected and safe (for example)
Then
Light = Turn on
    Thanks, the main problem was malfunctioning scenes creator, restore the system and problem solved.
    Sometimes it worked and sometimes did nothing.
