I connected my Fibaro dimmer to a retractive switch (push button) as follow:
- S1 for to command the light in the room, to be activated when press down on the push button
- S2 to command something else, actioned when pression up on the push switch
In the Group ID of the dimmer I added the other dimmers that I wanted to link to Group ID 2.
The problem is that when I press "up on the switch" the linked dimmers switch on/off/dim but not the main one.
How can S2 switch on the current device as well as the devices linked to it (ie if Group ID 2 = 1, 2 then switch on 1 and 2 and not just 2)?
I have v 1.044
With rooms:
- switch in Room 1
- Room 2 and Room 3 to also be switched on when pressing "up" via S2
Problem:
- only room 2 and 3 switch on when press "up" and not room 1
Thanks for your help
