Disable doubleclick
Guest Kuuno
Has anyone figured out how to have dimmes always go 100% when turned on.
I want to have dimming but not have dimmer memorize last state
Could be intressting when using switch manually to always switch on at 100%
Guest Sander
    +1 this is the only thing that frustrates the misses.
    On the HC2 home page when you click the dimmer switch 'ON' it always goes to 100%.
    So it should be possible to assign the manual switch to initiate a 'ON' command?
    Guest Kuuno
    exactly same thing here
