http authentication for virtual devices.
I can send http request to my external device using :
GET /web/remotecontrol?command=116 HTTP/1.10x0D0x0A0x0D0x0A
works nice, but now I protected my device with password & username (basic http .htaccess)
Anyone has an idea how I can send my username & password ?
Many thanks,
6 answers to this question
Guest GG
Try this
GET /web/remotecontrol?command=116 HTTP/1.10x0d0x0a
Authorization: Basic dGVzdDp0ZXN00x0d0x0a0x0d0x0a
where authorization code is : base64 encoded
    Try this
    Hi, thanks for the feedback, not sure if I'm doing this the right way because it's not yet working..
    Asuming login info would be admin:1234
    Then i need to use:
    Authorization: Basic YWRtaW46MTIzNA==0x0d0x0a0x0d0x0a
    right ?
    Many Thanks,
    Guest GG
    Then i need to use:
    right ?
    Many Thanks,
    It might be that you need to put the whole string on a single line, otherwise an extra LF is inserted.
    I have defined a virtual device like attached image and it seem to send the correct data.
    What I experianced was that if I delete all buttons in a virtual device and then add a new button, the new button seem not to work. Instead I deleted the virtual device and created a new one, then it worked for me.
    Many thanks for your help & time GG.
    Not sure why but can't get this working, might be a limitation from my device, not sure
    I did some tests with multiple http command lines and this seems to work.
    Sample:
    GET /web/remotecontrol?command=139 (call Menu)
    HTTP/1.10x0D0x0A0x0D0x0A GET /web/remotecontrol?command=108 (navigate down)
    HTTP/1.10x0D0x0A0x0D0x0A GET /web/remotecontrol?command=352 (start mediaplayer)
    HTTP/1.10x0D0x0A0x0D0x0A GET /web/remotecontrol?command=401 (load/play playlist)
    Pretty cool actually, it can display custom text messages on your TV screen, play your favority song when activating scene, pauze current channel and zap to IPCAM..
    Guest GrZeCh
    in my opinion you should use LUA. Check this fibaro doc (Net.FHttp):
    Of course you didn't mentioned which HC2 version you are using so it might be solution not yet for you.
    Thanks for the info, I'm using 1.044 (beta firmware 3.x does not work on my box, unable to login after update admin/admin didn't worked and unable to reset password). Got over 100 nodes connected to my fibaro so not sure what causes the update problem.
    So i guess I'll need ot wait for stable release.
