Beta API - http Commands (3.341)
Guest deraaij
Hi all,
Just to share for those who did not figure it out already, the following http commands work with the beta version:
Devices:
ID = device ID
name = action
arg1 = (e.g. value dimmer)
http:///api/callAction?deviceID=4&name=turnOff
http:///api/callAction?deviceID=7&name=setValue&arg1=39
Virtual Devices
ID = device ID
arg1 = button ID
arg2 = slider value (only for slider)
http:///api/callAction?deviceID=15&name=pressButton&arg1=2
http:///api/callAction?deviceID=51&name=setSlider&arg1=8&arg2=30
Notification
ID = Device (Iphone, e-mail et cetera)
arg1 = Notification template
http:///api/callActiondeviceID=9&name=sendDefinedPushNotification&arg1=1
Arm/Disarm devices
arg1 = 1 - Armed
arg1 = 0 - Disarmed
http:///api/callAction?deviceID=51&&name=setArmed&arg1=0
Scene
ID = SceneID
http:///api/sceneControl?id=14&action=start
http:///api/sceneControl?id=14&action=stop
Get json status from api:
http:///api/rooms
http:///api/scenes
http:///api/devices
http:///api/devices?id=316 # Specific value of a device
http:///api/virtualDevices
http:///api/globalVariables
http:///api/weather
http:///api/sections
http:///api/users
http:///api/energy/now-3600/now/single/devices/power/58
Updates used by mobile:
http:///api/mobile/interface/refreshStates?last=3058
Reboot:
Post --> http:///api/settings/reboot
etc.
change variabele example:
Unfortunately will not trigger scene (yet):
Mark
Guest deraaij
    Not works
    The url works but the value are unchanged
    Hi, in the first post you can find an example, it is only possible by using "PUT" instead of GET.
    Any Ideas in c#?
    Trying it through;
    Where uri is:
    and json is the json string of a variable.
    But I am getting a targetinvocationException. With an inner exception about reflection so something not right...[/code]
    I don't know C# but I think POST and PUT is different.
    Yeah I tried both... but same result
    Not works
    Yes i see it, but i have some difficul to make a PUT request with Python code with authentification, It is more easy for me with the GET method
    Haha same thing in C#
    Guest deraaij
    mhhhm i have certainly done it in python, unfortunately I cannot find the code (I am now not using it anymore as the API does not invoke a trigger currently, logged bug).
    I find it ! in Python
    Good luck for C# !
    Guest deraaij
    Good luck for C# !
    Please post it, so others can benefit
    Yes, no problem
    This is 3 request (Get, Post and Put) in python who works with the HC2 API.
    Virtual Device
    set a label value with ID Status
    set the icon
    If I understand, you say we can change icon status on virtual device???
    you can control
    the icon
    send text to labels
    in addition to slider and button
    Will there be a new version of xbmc plugin that pushes status and icon?
    Why not, I can check to do that as soon as I understand that virtual device.
    I will check tonight.
    [ Added: 2013-08-28, 11:03 ]
    If somebody have some good icon for xbmc on and off would be great.
    Guest merylion
    Seems like setting of global variable is not so easy.
    I would like to have some BAT file or something like icons on my WIndows desktop
    where each one is setting different value to one global variable.
    Then in Lua itself I will be handling this propertly
    I know that easier is to start scene but then I will have to create dozen of scenes as I am planning to have many shortcuts.
    Main problem is how to create any BAT file or any other application which can send HTTP request towards FIbaro
    Thank in advance
    Marcin
    Does anyone know the http command for the roller shutter module, to stop? I am using up and down command just like dimmers with %. I want to stop it, not in any particular position.
    This should do it:
    http:///api/callAction?deviceID=&name=stop
    What about thermostats and the time they should be active?
    to find the action names use the web api
    and you will get the settings of the device and the actions supported
    "actions":{"pollingTimeSec":1,"requestNodeNeighborUpdate":0,"setTargetLevel":0,"setTime":1}
    Guest Charly86
    Ok, this documentation is fine and help a lot.
    Unfortunatly I'am trying to "set" a value for a property of a device (a everspring st814), but it does not work, if anyone has a idea, I would appreciate. Id 27 = temperature sensor
    What I'm trying :
    curl -X GET "http://admin:[email protected]/api/callAction?deviceid=27&name=setProperty&name=userDescription&value=test"
    doest not work, neither
    curl -X GET "http://admin:[email protected]/api/callAction?deviceid=27&name=setProperty&arg1=userDescription&arg2=test"
    If you know how to do it in LUA I will take also, it drive me mad !!!
    Thanks,
