Guest Kuuno
id si correct, i have done lots of add remove devices so id is pretty big.
id 12 was hold down and 14 is doubleclick, i changed but result is the same...for some reason only single click works for me.
the parameter 3 is set to 2 as per manual... :S
EDIT:is there a way to debug the value the device sends from scene activation? fibaro:debug(scene activation id received)
got it:) fibaro:debug(fibaro:getValue(371, "sceneActivation"))
i set parameter 3 to 3 and then it started working (input monostable) is this bug in translation?
Kuuno
I am going to install 4 this week, i check and tell you.
Guest Kuuno
ok mystery solved.
parameter 3 value 2 is monostable. I was first doing this by counting the nr of parameter values where 2 value is normally open. so to use parameter must be set to monostable
UBS monostable is not a big deal
Try seting up scene activation with bistable Dimmer
anyway, if you give up you can find some help here:
