Good day ,
Yesterday I recieved the Fibaro 3 in1 sensor (FGK 101-107) after some problems including it (including is not pressing 3 times but 6!! times the button, also the tamper switch needs to be pressed :-s ) but finally I got the sensor to work.
And according the documentation you can use it as a scene activator , The documentation is quite poor and I have difficulties understating it , hopefully someone can help.
The idea is to use the 3in1 sensor as a doorbell activator , when pressing a springloaded button connected on this device it should activate a scene.
For the moment I connected just to wires to "ground" and "in", holding them together should do the trick for testing purposes. I also connected the DS18B20 temp sensor to the device.
Anyway , most important is that it can activate a scene, I inserted parameter 14 to 1 and parameter 3 to 1, see attached screenshot.
What next?
how do I tell a scene when I push the button it should activate that scene,I use the sensor in combination with a vera3 from micasa verde.
Hopefully someone can share some light.
One more thing , When I bought the device I thought it is a doorsensor ,temperature sensor and a binary input all together ( 3 in 1), but when I test the device I think it is OR a door sensor , OR binary input . Also the tamper switch is a bit vague , not sure if it works :-s
Many thanks,
Cor
