Aeotec 4-in-1 fully supported by now?
I'm in need for some multisensors. Three of which should be able to be mounted in humid environments, so the new Fibaro sensors won't suffice anyway I think (if they ever get released..).
The Aeotec 4-in-1 would suit my needs, but afaik only temperature is supported by the HC2. Now I've got a webshop that says the sensor is fully supported from 1.036 and up. Is this true?
  • Answers 69
  • Created
  • Last Reply
By the way ..... In my system the 4in1 don't use USB power.
you need usb power and change parameters 102 and 103 if i remember correctly to eg 10 for 10 seconds... i have all mine set to 10 seconds anything less and its pointless as the sensor needs a few seconds to settle after each command i set it to 3 seconds to test and found it missed some actions!
So we have 9 Aeon 4-1 with motion/lux/hum/temp refreshing every 10 secs and its working very well!
If you don't go usb power then make sure you buy a lorry full of batteries!
Naaaa ... as far as i know parameter 102 and 103 is for group 2 and 3 (and the corresponding 112 and 113) .... but I think that you don't use it !!!!!
BTW : HC2 have template for 4in1 that permit association only to group 1
Scene that runs only if the light level is below a user set?
I found some LUA code for VERA that would run a scene only if the light level is below a user set threshold :
local LOW_LEVEL = 20 -- the light level threshold for night
local DEVICE_NO = 33 -- the light sensor device number
local LS_SID = "urn:micasaverde-com:serviceId:LightSensor1" -- the LightSensor service ID
local currentLevel = luup.variable_get (LS_SID, "CurrentLevel", DEVICE_NO) or 0
currentLevel = tonumber(currentLevel)
if currentLevel <= LOW_LEVEL then
return true
else
return false
Can someone tell me how can I implement this function for HC2?
I didn't manage to do that with scene with visual blocks..
has someone got a parameter 158?
Guest erkadevil
My unit is working apart from one thing. The temperature isn't showing, in fact there is no device at connected to temperature (see attached screenshot). Humidity and ligh is working fine. Parameters are set up as follows:
10, 1, 2, 225, 1, 300, 1800
Anyone got any ideas?
erkadevil, press reconfigure
Guest erkadevil
OK, the funny thing is that the device is still not listed (as in the screenshot), however: If I click on the motionsenesor it has three device 20.1, 20.2 and 20.3 and if I click on 20.1 I get the temperature sensor with a temperature value.
So how come it is not listed with the others in the "devices" tab?
[ Added: 2014-02-25, 08:51 ]
Well somehow I managed to get it going, thanks for your help
Wish we could have the fibaro sensor here soon, I suppose it will be easier to configure...
