Dimmer cabling
Guest ygh
I try to set up a dimmer and I have some issue in the cabling. I don't have any switch in my configuration - please see the attached document.
On each side I have 3 cables. Red (R1, R2) for the phase, blue (B1, B2) for the neutral and green (G1, G2) for ground ("Terre" I dont know how to translate).
Can any one advise which cable (R1, R2, B1, B2, G1, G2) should go the dimmer, please.
Thanks for your help,
YG
Hi, don't connect earth on dimmer but directly on the lamp. You must put live lead(red) from your power supply on fibaro dimmer L, put neutral (blue) from your power supply on fibaro dimmer N... Now your fibaro module is powered !
it only remains for you that has to connect the lamp: put your lamp neutral (blue) on neutral power supply or on fibaro dimmer N and the other cable on the O fibaro terminal.
Guest skyhooper
    Go to the easy way,
    "jamais sans charge"
    Bon courage
    Guest ygh
    Thanks - So to summarize, the recommendation is the following:
    - R1 -> L
    - B1 -> N
    - R2 -> O
    - B2 -> N
    - G1 and G2 together
    Can you confirm that S1 and Sx are not required because there is no switch, please
    I will test tonight if this works !
    YG
    S1 and Sx are not requiered if there is no switch in place !
    - R1 -> L
    - B1 -> N
    - R2 -> O
    - B2 -> N
    you are right...
    You can do this: see png.
    Guest ygh
    Excellent - Thanks.
    Will try that tonight !
    Guest ygh
    Works fine !
    Thanks again.
