Dimmer and relay switch not working after a while
I have a configuration with one fibaro 1,5 kv relay and one aeon labs dimmer, they works well but, after some time (variable may be 1 day or 2 hours) they stop to work, if i activate one of them on the web interface the icon lights turns on but the lights connected to the devices are not on. The message "Trying to send" is correctly showed but not follwed by "transfer ok". The system does not report any dead node and if i turn off the hc2 (by removing the ac plug) and then turn on again everything begin to work again. The some thing happens with scenes, sometimes the do not work and after a reset they works again. My SW version is 1.046. Any idea to solve the problem ?
Hi, you can reboot your box, it can help !
Many user report this problem with 1.044 and 1.045 update but 1.046 seems ok to me.
Also you can contact fibaro support, fibaro people can help you...
Good luck.
