Good evening
i have setup a DS18B20 sensor that i want to use outside to messaure temperature.
DS18B20 is recognized by the Fibaro sensor and it seems to work, at least for a while
/emoticons/default_icon_eek.gif" alt=":shock:" />
When i place it outside and it starts to go below zero it gives really strange temparture.
Any suggestions, or is it just that beta version of Fibaro does not have full support 4 it?
We have the same problem... See here
    If i revert back to version 1.40, will it work then?
    I think yes ! But I'am waiting fibaro reply about the problem...
    Now when temperature is over zero(0) it works
    Why cant Fibaro people come out with an update or at least answer why it does not work below zero
    /emoticons/default_icon_question.gif" alt=":?:" />
    @Krikroff,
    have you got any info from fibaro yet? Atleast they could come out with an update
    Sorry, no news from fibaro ! It seems they can't reproduce the problem but in fact not respond at all and save time before next update, it's a pity !
    You can try to contact fibaro support.
    Good luck
    Reply from fibaro support
    Dear Sir,
    It should be fine in 1.046 butnotin beta 3.341. We are testing right now 1.047 and new beta. Please be patient.
    Pozdrawiam,
    Bartłomiej Kreczmer
    Fibar Group sp. z o.o.
    Ul. Lotnicza 1
    60-421 Poznań
    Poland
    Email: [email protected]
    Tel : +48 731 220 429
    Web: www.fibaro.com
    NIP: 781 185 80 97
    KRS: 0000370151
    KZ: 1 000 000,00 PLN
    Yes It should be fine in 1.044, 1.045, 1.046
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    I use DS18B20 outside and it shows correct temperatures, even negative.
    My HC is on 1.044 so maybe the issue is connected with the next versions.
    I experience strange behavior with temperature (everspring ST814) since 1.045 update :->
    Dear Sir,
    We hope that it will be in this weekend.
    Pozdrawiam,
    Bartłomiej Kreczmer
    Ul. Lotnicza 1
    60-421 Poznań
    Poland
    Web: www.fibaro.com
    NIP: 781 185 80 97
    KRS: 0000370151
