Small Iviewer (command fusion) test
Guest deraaij
Guest deraaij
Inspired by Adv.Usr.sztywniak's example on openremote, I did a test with Iviewer / Command fusion and fibaro:
Mark
9 answers to this question
Guest sztywniak
  • Congratulations, looks beautiful
    Guest deraaij
  • Sorry was not able to post is sooner but the dimmers also works:
    Hi Guys,
    I want to integrate The Fibaro system into Command Fusion and Demopad are you able to point me in the right direction for commands, replys 2 way feed back etc?
    BTW I am very new to Fibaro.
    Thanks in advance
    Regards
    Peter
    Guest deraaij
  • Hi,
    For api commands see:
    I use a control system (basic test written in python) (which I run on my NAS, to decouple command fusion iviever and the HC2, see:
    You can also use iviewer without a self-made control system see:
    for more info.
    If you have questions let me know (sorry for my lag in respond time but I am really busy at work......
    Hi !
    How do you make synchro between command fusion and HC2?
    Because when you put light on with iphone application, immediatly the iviewer can see it...
    Do you pull it every second? or there is timeout on HC2 that inform you on change?
    Thanks!
    Guest deraaij
  • Hi !
    Thanks!
    I made a scene which triggers on a state change and communicates this via TCP to my, in the middle, commandfusion (python) control system
    Hum ok !
    interresting!
    Can you put a part of your script...?
    Do you know if we can do this with fibaro API..?
    Because with VERA (micasaverde) API, there are a timeout function that say when a device change state...
    I look on fibaro API with chrome developper windows, and i see a request that tell what device are change...
    When nothing change the answer is :
    If something change it say us :
    There are 2 parameter "last" and "rand" but i don't know how use it... and i don't know how make for this timeout answer...
    If you have idea...
    algeroth, the 'last' value is returned by HC2 reporting the last time a change occured.
    The 'rand' value is optional and I guess it is used by HC2 as a 'heartbeat'.
    When you want to use api/refreshStates from an external application, you first request it without parameters:
    ip/api/refreshStates
    The HC2 will return a value in 'last' parameters that reflects the last time a change occured with any device.
    You then use this 'last' value as a parameter and the HC2 will respond with the list of devices that recorded a change in their status:
    ip/api/refreshStates?last=
    Hope this is clear enough.
