Dimmer Fibaro
Guest pablotibis
I bought a dimmer fibaro, when I give the order to turn the lamp can indicate a fade out, you can do even when you turn the lamp to do it slowly?
If I understand correctly:
Check parameter 10. if you set it to 1, it will take 1s to turn off/on when you flick the switch
However, it does not work for all lights - you might have to set it to 0 to work properly.
Guest pablotibis
    thanks
