Reset fibaro 3 kw switch
Guest Lode
Can somebody tell me how to reset the 3 kw switch ?
I tried everything according the Manuel but nothing works.
Tried to include in hc2 but nothing.......
It's driving me crazy
I had same thing just few hours ago.. I left it alone and suddenly it was OK. Actually only thing I did (after few restarts to HC2) I changed the language to Estonian and this 3kW relay just was there.. and worked fine. (Beta)
Hi Lode,
My basic troubleshooting when I get this problem with any device is:
1) is the node close enough to the HC2? In add direct coms is required. I have to move my HC2 to get to the far end of my setup. (I do live in an old property with some walls over 1m thick though...so I have poor radio. It takes 5 wifi access points to get end to end coverage.)
2) try removing the problem device first. Do that a couple of times to be sure the memory on the device is clear.
3) try cycling the power and make sure the s1 input is off before starting add
Hope that fixes it.
Guest Lode
    Thanks to both of you, i will try that
