Basic Code Clips for LUA starters
To help those that are not familiar with LUA a starter library of clips that work in Fibaro.
Please add any you find useful.
  • Answers 151
  • Created
  • Last Reply
Ok
Problem solved, it works
I'm having trouble with multiple click function and dimmer.
I want to do something like this:
2clicks - turns ON my bedroom light to 100%
3clicks - my house goes to sleep and bedroom light DO NOT turn on 100%
Right now dimmer recognizes two clicks every time and lights will go 100% - but its sooo bright then. I made a scene which dimmed the lights, but still this takes some time before starts..
how can I skip ID14 (2clicks) when I'm making 3 clicks
/emoticons/default_icon_question.gif" alt=":?:" />
I never made it working properly 3click function. I decided to stack to 1click plus long press...
example how to set up rain delay for drenchers or adjustWater
all data you can get from there
virtual device code
Arbu-jl,
try this one
Hi A.Socha, i tried your latest script above customizing it with my config, works perfect for the 1st heating section but then stops and i get the following error in the debug window:
"[ERROR] 20:27:10: line 25: attempt to call field 'decode' (a nil value)"
Can you let me know how i can correct this ?
Geo
xXGEOXx, check ip hc2 and password in code
Hi A.Socha, exactly what I did first on top of editing section id. I just checked again and I have my ip and password associated to my box in there. it does put the first section on holliday temp, the problem happen starting at the second section id where for some reasons it seems not able to retrieve current set temp...my section id are 3,4,5,6,7 and 3 is well set on holliday mode. If ip/password were not correct it wouldn't even change the first section id, correct ?
Geo
Looking forward a solution to switch off the heating when a bunch of windows / doors are opened.
Idea is to add a list of door / windows sensors, if they are opened for more than 5 minutes for example, then heaters (electrical heating) are turned off until door is closed.
When the doors / windows are all closed then, have to wait for 10 minutes (for example) then enable again the heating as it was before.
Do someone has same kind of code to share (maybe LUA code I think, or nice integrated feature ?).
Xavier
-25 and +25 is how many minutes after or before sunrise/sunset
Hello jompa, thank you for this example. I'm new to lua and the problem that I had with this example is that you have to wait until the next sunrise and sunset occurs before the global variable "Night" is set.
I modified your code and came up with the solution below. When you run this, It will set "Night" immediately.
Jan
Any solution? Have the same issue.
    try
    Problem with code is that the variable json containing a string is created that shields the true json variable that has all the methods so in the second pass json.encode and json.decode are nil
    robmac,
    thanks a lot - it's working
    Andrew, could you please change the code so that everyone can use the proper one?
    It's very handy.
    Hi, could anyone make me a sample for such scene:
    If variable "something" is 1 then run the scene ID11 after 5 hours (18000sec).
    Should it work with block scene or this time is too long for block? How to do this with LUA?
    On the Fibaro website (
    ) they have an example on the bottom of the page that this should work:
    But it doesn't... it just fires directly. So I gues that's a bug. Because it would be very nice!
    Hey,
    thank you very much - it works
    huh? how? mine doesnt....
    I made such scene, marked both boxes - scene active and start with hc2.. and worked like a charm.
    MHH gonne test it again. Because I did it with 3 minutes and that worked perfectly! now with 55 it fails :\ so maybe it has got something todo with the time...
    I made another one with 5hours, Im gonna check tomorrow, if it has worked or no.
    Lauri, be sure to have uncheked checkbox for global test
