Adding power to the Fibaro Universal sensor
Guest Lode
Just bought a universal sensor but I don't know how to add power to it.
I have a 12v power supply with two wires (+ and -).
Somebody ?
Thx
Lode.
Did you got manual as well??
Have a look:
Power (+) is red wire and blue is negative (-).
Guest Lode
    Hi Lauri,
    First i want to thank you for all your quick replies.
    People like you keep me going
    Of course i have the manual but it says red=live and blue=gnd
    This is confusing me....
    Are your sure i can hook it up the way you told me ?
    Yes, I have done this several times (also connected one universal module to my car battery - to make car module).
    I also add a picture of the explanaitions (link I gave you)
    Guest Lode
    Ok, so i'm going to add the red wire into p and the blue wire into gnd.
    Then.......
    I have a magnet contact i want to use with this sensor.
    State of this contact is NC (normally closed)
    When the contact changes state, so when it opens i need a z wave signal to report me that.
    Do you know if this is possible ?
    Please become my hero
    It should work fine if you attach this to input 1 or to input 2.
    Guest Lode
    The contact has two wires, so i put them both into IN1 or IN2 ?
    There is 4 contactors on universal sensor. Two of them belongs to IN1 and two are for IN2. You take your magnetic contact wires (2wires) and contact them to lets say IN1 pins one to one connector and second wire to second connector.
    Guest Lode
    I tried that already but it doens't work
    I,m looking around to adjust the parameters.
    Guest Lode
    Sorry but i didn't do it right.
    Wich two belong to in1 and wich two belong to in2 , can you give the colors ?
    Please check user manual - IN1 and IN2 are not the wires. These are screwed connections on the other end of the sensor.
    Guest Lode
    Lauri,
    I did check the usermanual several times but the other side of the sensor is (according diagram 1 ) out1 and out2.
    Yes - It is me who has to read manual
    /emoticons/default_icon_mrgreen.gif" alt=":mrgreen:" /> Sorry!!
    Correct way to install magnetic contact should be IN1 wire and GND wire - if they are connected then the status is changed.
    Guest dsilletti
    Hi all,
    In 1 is the yellow, and In 2 is the green, so connect your sensor to the yellow and blue and that's it.
    Regards
    Guest Lode
    Yessssss, it works.
    I see device 003.1 gives alarm when i open the contact and back to normal when i close the contact.
    So i suppose that 003.1 mens device 003 in1, correct ?
    Thanks guys !!!
    • 1 month later...
    Does it possible how did you connect on your car??
    I connect the red and blue on the battery, but in1 and in2 don't really understand how to connect because they appear like motion sensor in HC2.
