Dimmer Fibaro Scene Activation Parameter No 41
Guest Baloo
I am using the Fibaro Dimmer FGD – 211 v.1.9 – v.1.11 and want to activate scene-control using the options double and triple click - as described in the manual under Parameter 41.
My question is: How can I “read” out the scene ID:s? I am using IP-Symcon software with Tricklestar Dongle.
I do not understand anything about "Scene activation functionality".
Documentation is really not clear
/emoticons/default_icon_redface.gif" alt=":oops:" />
Where can I configure HC2 and give the scene to run depending on the trigger on the push button (clic, double clic, triple clic)?
Do you have an expérience?
Regards.
mlier,
create lua scene, example you got here
Thanks for the answer. It works.
Fibaro needs really to write a good documentation of the basics of Lua in HC2.
For instance, how works the first lines of each scene
%% properties
%% globals
etc...
When can we get some documentation and help on Setting Scenes, parameters and associations.
I see a lot of people on here talking about it and who seem to understand this but as someone new to this (and spent over £1500 on HC2, sensors, switches, etc) it would be nice to have some clear and helpful documentation to support it.
@A.Socha
Please a bit more information how this scripts works.
Device ID is 507
What are the other different scene ID’s
and why so much different clicks?
507 - id device
local name - name of device
example is for dimmer, script show every possibility in scen activation what you can get, and will write in debug info what you pressed
Thanks. Going to try.
It's not my favorite option more than once click.
WAF-Factor of is very low when you have to do things that are hidden...
TANE, that script we can say is universal
for dimmer it wil work
for ubs it will work
for door/window it will work
- you got full control on what hc2 is getting so there is no situation that you pressing button and no reaction
- you can create new scene for example for 1 click s1 and you paste only 1 command in that script
A.Socha,
thanks for your script. I am however unable to activate triple click on my dimmers S1. It gives me scene activation 14 still... Which is double click.
Am I missing something?
parameter 15 is on 1? (double click on)
what value you got in parameter 14?
what type you got buttons?
P15: Double Click ON
P14: Monostable
And the actual switch has a spring which pushes the button back.
Triple click yields the same as double click.
setting are ok, can you try faster push button?
Sorry for late response.
I've tried both fast (0,6s for 3 clicks) and slow 3 clicks in 2 secs.
Tried writing some code for using it as well, but it seems to never switch out of the activationScene which caused my code to inf loop since I ran the check in a while loop. Is this the intended function of that parameter or is it stuck?
can you paste result of debug my code?
using the following (modified loop version of yours):
debug output:
Video of switch presses:
Lockzi, can you do a test? i think i see where you got a problem
use that code
press 1 time button s1
press 2 time button s1
press 3 time button s1
press 4 time button s1
press 5 time button s1
and if its ok say ty, if not paste debug
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20">
Sorry, but debug output it is... Although it did for one instance actually say 3, before switching to 2 (I did not click any more before it changed to 2 by itself).
you got strange result of debug
you should get for 1 click only 1 click but i see that you got 2x 2 clicks? impossible
can you try again (please dont press more then you should)
wait 3s
wait 3s
wait 3s
wait 3s
wait 3s
wait 3s
wait 3s
wait 3s
Ok,
one moment please.
[ Added: 2013-04-26, 23:48 ]
With slow pressing... (forgot 4 clicks though)
Video:
[DEBUG] 23:16:24: Cristal
[DEBUG] 23:16:24: 1 click s1 16
[DEBUG] 23:16:27: 1 click s1 16
[DEBUG] 23:16:30: 1 click s1 16
[DEBUG] 23:16:33: 1 click s1 16
[DEBUG] 23:16:36: 1 click s1 16
[DEBUG] 23:16:39: 1 click s1 16
[DEBUG] 23:16:42: 1 click s1 16
[DEBUG] 23:16:45: 1 click s1 16
[DEBUG] 23:16:48: 1 click s1 16
[DEBUG] 23:16:51: 1 click s1 16
[DEBUG] 23:16:54: 1 click s1 16
[DEBUG] 23:16:57: 1 click s1 16
[DEBUG] 23:17:00: 1 click s1 16
With fast pressing
Video:
[DEBUG] 23:17:50: Cristal
[DEBUG] 23:17:50: 1 click s1 16
[DEBUG] 23:17:53: 1 click s1 16
[DEBUG] 23:17:56: 1 click s1 16
[DEBUG] 23:17:59: 2 click s1 14
[DEBUG] 23:18:02: 2 click s1 14
[DEBUG] 23:18:05: 2 click s1 14
[DEBUG] 23:18:08: 2 click s1 14
[DEBUG] 23:18:11: 2 click s1 14
[DEBUG] 23:18:14: 2 click s1 14
[DEBUG] 23:18:17: 2 click s1 14
[DEBUG] 23:18:20: 2 click s1 14
[DEBUG] 23:18:23: 2 click s1 14
[DEBUG] 23:18:26: 2 click s1 14
Could you please try the same code as you posted with one of yours just to work out if there is a problem on my end or with the code.
Can you somehow output all of the configurations of an Z-Wave device?
