lua nightlight scene
Guest Kuuno
Guest Kuuno
what could be wrong with this script as it makes HC2 go crazy?
the point is to check if ti is night and if night light is 1
in case of turning light on it will go to value 10 and disable the night light variable so you can turn light on fully if wanted
after turning light off the variable goes back to 1
%% autostart
%% properties
12 value
%% globals
Öö
2k_wc_nightlight
if (
( tonumber(fibaro:getGlobalValue("Öö")) == tonumber("1") )
and
( tonumber(fibaro:getGlobalValue("2k_wc_nightlight")) == tonumber("1") )
and
( tonumber(fibaro:getValue(12, "value")) > 0 )
or
then
fibaro:call(12, "setValue", "10");
fibaro:setGlobal("2k_wc_nightlight", "0");
elseif (
( tonumber(fibaro:getValue(12, "value")) == 0 ))
then
fibaro:setGlobal("2k_wc_nightlight", "1");
thanks
[ Added: 2013-02-17, 20:55 ]
/emoticons/default_biggrin.png" alt=":D" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> figured it out, it was missing check for variable in elseif part
full code here to not blin yourself at night when goinjg to toilet but still being able to turn light fully on
same could be used to sovle the problem when dimmers used to go to saved state always...
%% autostart
%% properties
12 value
%% globals
Öö
2k_wc_nightlight
if (
and
and
or
then
elseif (
and
( tonumber(fibaro:getGlobalValue("2k_wc_nightlight")) == tonumber("0") )
then
[ Added: 2013-02-17, 21:47 ]
still buggy
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> maybe someone can look over it:)
thanks
