Should the inputs S1/S2 always be switched to the module power supply (L) or can i use another supply?
Guest dsilletti
Only the load can be different, S1/S2 must be switched by L
Regards
Domenico
    I found this diagram on internet ... so this wouldn't work?:
    EdwinK,
    it would be better if you use the same Live signal
    Krystian, thank you for your answer ... i'm gonna go for the universal sensor + relay.
