Universal sensor v1.9 firmware and DS18B20
I am trying to get a universal sensor working with a temp sensor DS18B20. I have it on a 12v supply.
I have tested the DS18B20 sensor on a fibaro door sensor and it works but I can not get it working with the universal sensor.
I have tried resetting adding and removing the universal sensor many times but no luck. The universal adds only as 3 nodes (1 parent and 2 motion sensor child) no temperature.
Please could someone that has one of these working share any hints or does this not work on this firmware?
Guest simryc
Check wiring
Chceck if gnd is gnd vcc vcc etc
    Check wiring
    Thanks for the hints. Unfortunately all connections are correct and the temperature sensor was tested and is good.
    Are you using v1.9 firmware?
    Edit: Found the signal wire was damaged :->
