Set light through scene
Lockzi
been busy playing around with other things in the HomeCenter. I have now finally come across the scenes.
How do I create a scene (i.g. Party, day, lounge, evening, bedtime) that just sets the lights to my liking, not beeing triggered by a condition or event - just when I specifically run it?
I can not get it to work with the blocks, only through LUA - is this correct?
7 answers to this question
Guest Lode
Name the scenes party, bedtime......and turn lights on what you want for that scene....
I don't understand what else you want to do ?
Guest skyhooper
And if you want to dim light just put the value in the green zone like 20 for 20% dimmable ,and 10 for 10 seconds after in the red zone.
You can also create a can be triggered variable if you want to start scenes with.
Very simple
Guest Lode
It doesn't matter what condition you place first, if you push the startbutton of that scene it always runs.
  • It doesn't matter what condition you place first, if you push the startbutton of that scene it always runs.
    What happened to me was that I had All on and All off.
    My apartment became a disco because the scenes were running continuously.
    How do you "end scene" after end of execution?
    Does it make sense?
  • Can you post a screenshot of your scènes ?
    Just understood the problem with my scenes, I had a condition that was true for both all on and all of which caused the disco.
    I have now created a dummy variable that it checks against (I don't want it to run automatically, just when I initiate the scene manually). Is there any way to remove the condition for clarity?
    Guest Lode
    You always start with a condition when you want to do it that way else you have to do it by LUA.
    Depends on what version you run.
    In V1.047 you can't build LUA code.
    Whit the latest beta you can but it's pretty unstable.
