Placed this code in a virtual buttun but i dont get it to work, need some help.
5 answers to this question
Guest jcs10
I saw in an other post that this has to be in a virtual device, I don't know how... but seems to be working, if somebody could help ???
Guest sztywniak
try this code :
Guest jcs10
Thank you very much it's working !!
shame on me, I was testing this in local (checking the website logifile) but I gave the IP for the HC2....
Now I have to find an english, or french system that's doing the same as temperatur.nu...
    Ohh! to much typed in url on HC2 = Net.FHttp line
    Thanks for that input, now it works
    Guest jcs10
    Is it working the same way to send this info as "json" ??
    I should have to put :
    "feed_id": 28108,
    "value": ..temperatur
    on an URL
    ...I'm new to this maybe I'm totally wrong ?
    I tried this... but...
    [ Added: 2013-03-10, 22:34 ]
    at the end of the weekend, I have now this :
    This is working, but when I try to update it doesn't work many times (I had figaro:sleep(30000) )
    I get in green 0 and after that 200 on the virtual device
    and sometimes 180 or something going each time greater and the 200 code a little bit later.
    Any Idea why ?
    I's like to use sen.se, that look much greater, but they want json.... and I don't know how to do this
    It's my example code that should put 45 in the feed 28108, I think something may be wrong, but what ??
    -> How can I correct this ?
    -> I hop I can add
    and replace my value in json with outside
    Or am I waiting something to difficult ?
    [ Added: 2013-03-14, 22:45 ]
    no help for me ?
