Temperature not updated with FGK107 and DS18B20
Guest guidetti
Software version 1.047
The temperature shown inside the home center 2 is not updated as it should do. While the associated switch changes state in accordance to the temperature range specified in the heat panel (defaut deltaT to 0.5degrees) it is practically impossible to understand the room temperature and if the temperature control works well, the update time between two consecutives values is too long, sometime 10 minutes, preventing any realtime temperature monitoring . Any suggestion?
