Door Bell
fxpa
Hello
I've bought a Zwave door bell from everspring
I can't include it to HC2
Do someone have already try to include it?
Tks
FXP
Guest b95_lun
I found some documentation about everspring door bell UTSE03.
Google for everspring_utse03a_product_sheet_us.pdf
I managed to get both the push button and the door bell included to HC2 but both are seen as remote controllers and I haven't gotten further yet
[ Added: 2013-03-10, 17:14 ]
Hi I manged to make the door bell speaker play a tune with lua script (instead of 60 insert the device ID of the door bell)
Please look her:
Maybe you can found some useful information. I think you can try (after inclusion into HC2 both Bell and Button) make manual association (from Button to Bell) as descr. in article:
"For inclusion, I recommend you read the help page for eedomus . She explains the procedure. From my side, I connected the bell and chime on my eedomus, here is the procedure I used:
1 - Inclusion chime by pressing 3 times (IER)
2 - Inclusion of the "Doorbell Button" by pressing once (IR) for 10 seconds (leaving supported)
3 - Both devices are created in the box.
4 - Now you need to bind (associate) units together.
5 - Press the (IR) button for 10 seconds on the "Doorbell Button" (the "Push" button flashes)
5 - Press 3 times (IR) button on the "Doorbell Button" (the "Push" button flashes)
6 - Press 3 times (IER) on the chime unit (both buttons will stop flashing)
Now your doorbell is configured. You can try. If it does not work, you must reset the doorbell and the chime and repeat the procedure. I have been back 2 or 3 times to get there ... Do not despair! "
