Ping iPhone instead of GPS localization
Instead of using the GPS localization which consumes enormous amounts of power from the iPhone, I want to let the HC2 ping every minute if it can find the iPhone on my local network.
And based on that set a value if somebody is home or not.
Since 3.486 os.execute doesn't work.
Anybody have an idea how to use that function?
This is what I want to do:
Edit:forgot the while true do.
  • Answers 102
  • Created
  • Last Reply
On the status log from the device. Similar as status updates from z-wave devices.
INteresting. In the top part of the window you mean? Nothing appearing there...
Here's my (very basic and similar to above) script:
tcpSocket = Net.FTcpSocket("10.0.3.104", 62078)
bytes, errorCode = tcpSocket:write("test")
if errorCode == 0
then
fibaro:setGlobal("RonaldThuis", "1");
fibaro:log("Ronald is thuis");
else
fibaro:setGlobal("RonaldThuis", "0");
fibaro:log("Ronald is niet thuis");
I also have a very basic block scripts which 'presses the virtual button' every minute. I sometimes DO see my global variable changing, but I see no log appear in the status window.
Also: does anyone know how long the tcpSocket:write() tries before it times out?
Thanks!
Ronald
Guest deraaij
Example (just a test virtual device) Green text.
Ach..... fibaro:log("Ronald is not yet awake...")
/emoticons/default_laugh.png" alt=":lol:" />
Thank you. That works.
Guest deraaij
you are welcome
Works perfectly thank you so much
BUT!
anyone have any idea what port to use on an Android device eg Galaxy S3?
Guest deraaij
BUT!
I am not sure as I don't have one, you can check with a port scanner.
Port 55000 works with Samsung TV and Galaxy just for reference
Guest Lode
BUT!
Try to find out what port your phone uses for sync with other devices.
This one you can use.
On Ipad i use "fing" to scan ip's and port
There's also an android version of this app.
Guest sztywniak
Galaxy S3 1108/tcp
Need some help to make this code compleet.
Turn On desk light when computer Online else turn Off
Guest deraaij
You want to use this as a virtual device button? (that has no triggers) in the current version (beta 3.506) NET library does not work yet in scene's.
You could make a scene which pushes the virtual device button every minute and use this code on a virtual device:
@Mark,
The code need to be entered in the string to send field in the Virtual device button
Guest deraaij
@Mark,
check LUA code and then paste code.
thanks ...done that only getting the command ping faild
Desk light is turning off..
on my computer this is showing
localhost:631 (LISTEN)
I think 631 must be than okay..
Update
49315 is okay...
thanks.
Guest deraaij
Update
49315 is okay...
thanks.
you are welcome!
Tip:
If you are running dropbox on your PC/Mac poort 17500 is mostly open.
all,
how do you create a scene that presses the button on the virtual device ?
regards
john
Like this
Ahh of course, I was opening the devices not virtual devices, thank you
Is there a way to adapt this for more than 1 iPhone? So if my girlfriend comes over and I pop to the shop all of the lights don't switch off when I leave ?
So it could say something like
If john_at_home = 0 and kat_at_home = 0 then switch off the lights
Make a separate button (on the same virtual device) for each phone. You don't need a Target IP in the General settings of the virtual device. The script will handle this
