Ping iPhone instead of GPS localization
Instead of using the GPS localization which consumes enormous amounts of power from the iPhone, I want to let the HC2 ping every minute if it can find the iPhone on my local network.
And based on that set a value if somebody is home or not.
Since 3.486 os.execute doesn't work.
Anybody have an idea how to use that function?
This is what I want to do:
Edit:forgot the while true do.
  • Answers 102
  • Created
  • Last Reply
ok so ive god mine to welcome me home that wont keep turning the lights on every minute, so it checks to see if ive been welcomed already.
is there anyway to speed this up ? especially the iphone poll.. i find it can take up to two minuted to switch the lights on presumably because it can take upto a minute to poll the iphone and then another minute to check if the variable is 1 before the lights come on.
regards
john
regards
john
I think if you write this in LUA, you can determine yourself how long the delay is between subsequent checks... There's typically a fibaro:sleep(60*1000) statement in there... Change 60 to 15, and it'll check every 15 seconds. Not sure what that will eventually do to the performance of the box but give that a try...
thats better, that took about 5 seconds XD now if only i can increase the range of my wifi so that my iphone can pick it up at the end of my road i can then use it to activate the driveway lights before i actually get on the driveway. Thanks for your help everyone
for your help i shall post my scenes
This is the code to find out if your iPhone is within the range of wifi every 10 seconds
And here is the scene for activating the Hall lights
finally this one checks to see if you are home and if not, turns off all of the lights and reset the "Welcomed" flag
Is there a way to adapt this for more than 1 iPhone? So if my girlfriend comes over and I pop to the shop all of the lights don't switch off when I leave ?
So it could say something like
If john_at_home = 0 and kat_at_home = 0 then switch off the lights
I have this programmed is 6 scenes and a bunch of global variables:
If Ronald or Katja gets home, and it's dark, switch on Kitchen light
When both of us left, switch off the light in the kitchen
I have separated the coming home & leaving detection for both of us. Just like you, I keep two variables to remember the status. When either one of use comes home, I call a "ArrivingLogic" scene. When either one of us leave, I call a "LeavingLogic" scene. In those two logic scenes I do my 'OR' (he OR she are home) or 'AND' (he AND she are gone) logic, where I also check if it is dark outside before the lights go on... Pretty neat!
DM me if you want the scripts; a bit too much to post them all 6 here...
Do you still use that code to check the iPhone presence? Does it work properly?
In my case very often the check shows that I'm out even if I'm at home with my iPhone connected to WiFi!?
It's because iPhone is visible and respond to ping only when it try to sync with mail and cloud every xx minutes, it's the limitation of this script...
Anyone have any idea how to make sure that it will work more raliable?
Well... that's not my experience. I do use the script to determine if either my girlfriend or me are coming home, at home or leaving home, and switch on and off some lights as a result.
It appears to me that my iPhone remains connected to my WiFi, also if I am not using it. As a result, the ping succeeds whenever I am at home. I am checking my iphone every 20 seconds
Here's the ping scripts I use in my virtual device:
tcpSocket = Net.FTcpSocket("192.168.1.100", 62078)
bytes, errorCode = tcpSocket:write("test")
if errorCode == 0
then
fibaro:setGlobal("RonaldThuis", "1");
fibaro:log("Ronald is thuis");
else
fibaro:setGlobal("RonaldThuis", "0");
fibaro:log("Ronald is niet thuis");
And then I have this very basic LUA script which runs every 15 seconds. Button 1 my my iPhone, button 2 is the boss' phone:
%% autostart
%% properties
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart")
then
while true do
fibaro:call(86, "pressButton", "1");
fibaro:call(86, "pressButton", "2");
fibaro:sleep(15*1000);
else
if (startSource["type"] == "other")
then
I was a bit afraid that long term failing of these tcpSocket:Write() calls would make the box hang eventually, but it's been stable ever since I started using it.
Guest jrkalf
This is correct, it's build in to the OS to conserve battery life
Perhaps, but that's a long shot and a bit off a stretch that would require some coding, have a raspberry Pi with a Bluetooth dongle attached and pair it up with your iphone. As long as you're paired with the iPhone, you're home. And range of the bluetooth dongles can go up with 100m for a class A device?
As far as I know the intermittent issue as with WiFi isn't implemented for bluetooth.
I hope you find a solution for that.
[ Added: 2013-04-03, 15:33 ]
Ronald,
What iOS version are you using on your phone. Is it iOS 6.x or are you running an older phone with iOS5? The ping issue is a known issue I've been briefed on by a network expert at a previous consulting job. It's hardcoded to drop WiFi if the phone is locked for a period of time to conserve battery.
This is an iOS 6.x issue in sleep mode, the wifi is disabled...The IP no longer responds about 10 seconds after the phone going to sleep. But from apple forum (non checked...) It seems if the phone is plugged into a charger, the WIFI stays active.
No problem with iOS 5.x.
All the best.
I've been "pinging" my iPhones every 10mins and if I have left it for half an hour it would usually, but not always, stop responding.
Maybe if you ping it every 15 seconds as rvorsten is doing it would keep it awaken? I will try it and let you know.
PS
I'm using iOS 6.1.3
    Works here 99,9% of the time.
    With an iPhone 4 and 5 both running 6.1.2.
    Couple of times it said it was not online.
    But my wife came home 3 hours ago iPhone is still in her bag and HC2 pings it just fine.
    I run the script every 10 seconds. See no extra battery drain.
    E-mails get pushed to the device like always when they arrive.
    After changing to 15 seconds so far so good
    Thanks for the tip - now it's usable !
    Works also fine here.
    It will be great to have direct ping without checking a port.
    I like to se the status of more devices. some of this devices hase no open poort
    +1 Indeed, would be nice if Fibaro just created this function.
    Guest deraaij
    I agree! I was using os.execute before, needing open ports feels like a work around. Hopefully they implement something like fibaro:ping(192.168.1.1). We should submit a feature request.
    Thank you...Fibaro I hope we can see this in the next beta..
    Some more options are also welcome
    - ICMP
    - TCP
    Create devices for every IP unit and display the status
    Like Laptop Online (since 0:4:23)(D:H:M:)
    Printer Offline (since 2:10:15)
    Webserver (www) online since 14:5:15)
    iPhone online since…..
    Also more control from the scenes will be great
    Something like
    When iPhone becomes offline after 5 times ping…
    User is not at home
    When laptop becomes offline after 2 time ping
    turn off the desk light
    When Laptop online
    Turn on the Printer (power on/off)
    When TV offline
    Turn Off the settopbox
    This are all domitica related.....
    Guest deraaij
    thnx, sorry was busy .....
    My wife was quite surprised when the garden door has opened, and lights at the hall has switched on at her arrival close to our house. Start to like this solution
    Anyway, real PING would be even more usefull.
